Mazda of the Month | VOTE NOW for March!
VOTE NOW for March!
  • Total voters
    51
  • Poll closed .
Status
Not open for further replies.
Antoine
Administrator
Welcome to the Official Mazdas247.com "Mazda of the Month" Contest!
* The MOTM is OPEN to ALL Mazdas! *
Please note the following rules & guidelines.
Your cooperation and participation would be greatly appreciated, thank you.
ENTRY RULES
* You must own the Mazda you are entering into the contest
* Any form of photo/image manipulation is not allowed except for adjusting and enhancing image color, contrast, tone and levels etc
* If you wish to enter two or more times in a row, you will need all new photos of your Mazda for each consecutive month entered
* If you become a MOTM winner, you may not enter the same Mazda again until at least 12 Months after the month you had won. However, if you own several Mazdas, you are welcome to enter those as well * Each Member may NOT enter more than one Mazda per MOTM contest * Previous MOTM winners who wish to enter again (after 12 months) must enter with all new photos of their winning Mazda
* Once you have entered (posted) your Mazda, you may not withdraw from the contest
* The MOTM contest & rules are subject to change in order to maintain a fair & fun environment for the Mazdas247.com Community
ENTRY REQUIREMENTS
* Each contestant must submit three single high-quality high-resolution images of their Mazda. One image must be of the exterior, another the engine bay and finally an interior shot. Compilation style shots (multiple images within a single image or picture size frame) are NOT ALLOWED!
Format
1. Username
2. Name
3. Model name + (Year)
4. ONLY 3 Images (one exterior + one engine bay + one interior shot) NO ATTACHMENTS PLEASE!
5. "Mod" List *Please make your list CLEAR & CONCISE!
Entry Tips
* Wash & Wax
* Clean your interior
* Clean your engine bay
* Choose an interesting location
* Choose a well lit location for photos
* Make sure your interior shot is clear and detailed
* Make sure your engine bay shot is clear and detailed
Example (Obviously, this is NOT my Mazda but for the sake of an interesting example):
Antoine
Antoine *
Mazda 767B (1989)
Performance Mods:
600hp 4Rotor
Exterior Mods:
Aero tuned for the track
Interior Mods:
ALL BUSINESS
Stereo Mods:
4Rotor
Awards Won:
Second in awesomeness only to the 787B
Recognition:
Raced at Le Mans...Helped lay the groundwork for the 787B which won Le Mans in 1991.
PRIZES
* A Mazdas247 T-Shirt and a pair of Mazdas247 Decals!
* Your Mazda showcased on the Mazdas247 Home Page!
* 5% off any Speedcircuit.net purchase made that month!
VOTING RULES
* All voters must have a postcount minimum of a 100 posts. The only exception to this rule is for MOTM participants who are also new members
* There is NO tolerance for PERSONAL CAMPAIGNING threads, posts, private messages (PMs), images or links (including signature and or image links). The creation of such ANYWHERE on or off the Internet including Mazdas247.com will result in immediate disqualification *If you are disqualified, your entry & poll listing WILL remain but your votes will be removed. Everyone will see that you broke the MOTM rules
* Creating GENERAL "Vote for the MOTM" threads and links is allowed and encouraged
GOOD LUCK AND HAVE FUN!
IukekiniProtege
Justin Therieau
2000 Mazda Protege ES
Drivetrain & Engine
KL-ZE 2.5l v6 Straight Neck
DXD SouthBend Rally Stage1 Clutch
PaceSetter Headers
Custom CAI
AEM DryFlo Filter
KL36 ECU
JE50 VAF
Adj. Fuel Pressure Regulator @42psi
03.5 Mazdaspeed Protege Axle-Back
MSP Welded LSD - Broken
MFactory Helical LSD
Shaved Flywheel ~12lbs
Tech Edge Oz-DIY-WB v1.0 Wideband O2
Prosport Oil Pressure Gauge
DIY Oil Catch Can
DIY Coolant Overflow Can
AWR Rear Motor Mount
AWR Transmission Inserts
AWR Passenger Inserts
AWR Front Motor Mount
Transmission Saver Bracket
Braille B2015 15lbs Battery
MSP Axles
OEM Cruise Control adapted to the v6
Custom Billet Aluminum Battery Tie Down
Suspension & Braking
Tokico Blues
Eibach Pro-Kit Springs
Racing Beat Rear Swaybar
CorkSport Front Strut Bar
AWR Urethane RSB Bushings
Hawk HPS Pads - Front
Centric Cermaic Shoes - Rear
KMR Rear V-brace Setup
Clunk Fix Brackets
Exterior
2001+ Sedan Front Lip
P5 Side Skirts
03.5 MSP Rear Lip
2002+ "Protege" Trunk Badge
Evil 'M' Emblem Front and Back
99-00 OEM Fog Lights
Custom Lower Grille Made from a P5 Grille
MB Weapons 17x7 +38 Wheels
Bridgestone Potenza RE760 Sport 205/45/17
TechOne 6000k Bi-Xenon HID Headlights
3000k HID Foglights
Mazda Tribute Washer Nozzles
Body Color Grille Trim
Protege5 Mirrors w/ Red Panels
VIS Carbon Fiber Trunk
Interior
2003 ES Black Interior Swap
2003.5 MSP Floormats
DGM C/F GloveBox Trim
DGM C/F Arm Rest
DGM C/F Cluster Surround
Redline Goods Shift Boot
Greddy Counter-Weight Shift Knob
RX-7 Nardi Torino Steering Wheel
Bronze Painted Gauge Rings
Bronze Painted Radio Bezel
Bronze Painted Window Switch Panels
Bronze Painted Door Handles
Pioneer AVIC-D1 Navi Headunit
Valor DVD Player
Pioneer Ipod Interface
Pioneer XM/Sirius Unit
MSP Amp and Sub Rack
Polk Audio 8" Sub
Alpine Type-X Components Up Front
Blaupunkt 6x9 Shallow Mount Rear Speakers
Alpine 400watt mono amp
Alpine 375watt 4-channel amp
MDF Trunk Floor
High Mount Brake Light Deleted
Carpeted Rear Deck Tray
B&M Short Shifter
05 Mazda6 Wiper Switch
05 Mazda6 Headlight Switch
Trunk Cargo Net
ForceFed Gauge pod
Harness Bar
Sparco 4-Point Harnesses
Mazdaspeed Protege Door Sills
Sparco Pedals
rally2003
2011 Mazda2 Sport
Corey Plotts
Engine Bay Pic?
Interior Pic?
Drivetrain:
Stock
Suspension:
Stock
Exterior:
Stock
Interior:
Blue flower air freshener
Brian_K
Brian Kogawara
2003 Protege5
Drivetrain/Engine
-MSP Manifold, S & J pipe
-MSP Heat Shield
-SR20 T25 Turbo
-FMIC
-2.5" Hard Pipes
-K&N Cone Filter
-MSP exhaust
-TurboXS type S BOV
-MSP BPV
-MSP ECU
-Mazda Milenia S PCV
-Yudkib Vacuum Block
-SLS Front Motor Mount
-Minerva Motorworks Rear Motor Mount
-AWR Side Motor Mount Inserts
-Kartboy urethane linkage bushings
-Exedy Stage 1 Clutch
-Stainless Coolant Catch Can
Exterior
-2003.5 MSP lip
-S204 Replica Polyurethane lip
-GP rear diffuser
-OC Autowraps Matte Black Roof Vinyl
-Tail light vinyl overlays
-Hella Supertones
-Carbon Fiber Stubby Antenna
-Various Parts Plasti-dipped
-Mazda6 Wagon Rear Wiper
Interior
-Forcefed Steering Column Guage Pod
-SunPro Boost Guage
-SU guage rings
-Pioneer Stereo w/ iPod adapter
-TWM Short Shifter
-TWM Shift Boot
-2003.5 MSP Shift Knob
-MSP door sills
-Amber Footwell LEDs
-Broadway 300mm Convex Rearview Mirror
-OBD2 Bluetooth Adapter
Suspension
-Ksport Kontrol Pro Coilovers
-Ford Escape V6 Front Endlinks
-HKPRO5 Adjustable Rear Endlinks
-Progress Rear Sway Bar
-KMR V-Brace & Linkage Brace
-MX-6 Rear Strut Bar
Wheels/Tires
-MX-5 17" NC Wheels
-Bridgestone Potenza RE-01R 205/45
-Forged Anodized Red Lug Nuts
Brakes
-2006 Mazda6 Front Calipers
-Slotted Front Rotors
-Ceramic Pads
Rosta
Cameron Ross
1993 Mazda RX-7 Touring
Exterior:
Stock
Interior:
Prosport center gauge pod with boost, oil pressure, and oil temperature gauges
Nardi Legend shift knob
Redlinesports ebrake bood and shift boot
Fire extinguisher
Bin mounted battery
Pioneer head unit
Suspension:
Ground Control coil overs on Bilstein Struts
Racing beat front sway bar
Radius rims
Powerslot front rotors
Stoptech pads
Engine:
Silicone rats nest conversion
Cmezz331
Cory Mezzenga
2003 Mazdaspeed Protege "Olivia" Black Mica
Engine / Drivetrain
ENGINE #2 (forged build in the works :))
Injen Cold air intake
Custom Hardpipes With HKS SSQV VTA
Forge Wastegate Actuator
2.5" custom exhaust (straight pipe) to a 3' axleback with apexi "muffler" (rofl)
TRANSMISSION #2, new OEM lsd
Exterior
2003.5 Rear lip
2003.5 wing
Custom projector headlights
Blacked out badges
Mazdaspeed grille badge
MNMAZDA.COM and MAZDAS247.COM stickers
Rally Armor Mudflaps
Interior
DIN gauge pod with AFR, Water temp and Boost Gauges,
Pillar pod With Oil temp, Oil pressure, Fuel pressure
2 10" mtx blue thunder subs with stock sub removed
Hula Girl dash ornament:)
Suspension
Stock Tokico blues with racing beat springs and sway bars, escape front endlinks, stock rear endlinks.
Wheels and tires
Stock Racing Harts powdercoated Black with Hankook Ventus V12 evo K110
Sport edition something or others with firestone Winterforce tires
pitbullman
Name?
2009 Mazda Demio (1340cc)
Full Aero Kit with 17 inch OZ rims
My engine is just 1340 cc but I really love my Mazda!
Speedpx
Paulo Rodriguez
2003.5 Mazdaspeed Protege
Exterior:
S204 front lip
Front grille DGM replica
Suspension:
Eibach pro kit
Clunk fix bracket
Engine:
Powder coated wrinkle red engine cover
Front mount intercooler ebay
Aluminum pipes ebay
HKS BOV
Interior:
Dual pillar gauge pod
Autometer boost gauge
Autometer air fuel ratio gauge
Dual gauge cluster surround
Spirit Rx-7
Henry
1993 Mazda RX-7 R1
Engine & Power:
street port 13b
apexi power fc, commander, 12psi tuned by RRR
defined autoworks V-mount kit
greddy elbow
petit ast
3 in downpipe
high flow cat
racing beat single tip catback
supra TT fuel pump
1300cc secondary injectors
aem water/meth injection
K&N filters
Suspension / Brakes:
BC racing coilovers
stock r1 strut bars
rebuilt calipers
goodrich ss lines
ate super blue brake fluid
ebc yellows
Wheels / Tires:
fikse fm10 17x9, 17x10
hankook rs3 245/40, 255/40
Exterior:
re rep rear diffuser
feed rep sideskirts
wingless hatch
r1 lip
as long as it follows the rules, you can enter anything (mazda that you own) you want dude.....
Well after verifying the votes (votes do not count from Members with less than 100 posts), it was really close and the winner is...IukekiniProtege! Congratulations!
Thanks again to all participants this month, stay tuned for the April Entry Thread...
Status
