mazda 2 (panda style)
haha, thanks. You guys need to make a mazda 2/demio etc. picture thread. I actually like that car a lot.
I think my car @ redline has 2nd gear 98km at the tachometer and 3rd gear 140-145...
I have 195-45-16 tyres but they are almost the same with 195-50-15.
I will post a video of my revmeter-techometer to compare.
good idea...!!!
Take a look at my video!I also have 4.1 fgr and oem 16' tyre size!
What tyre diameter had you when you filmed the video?
http://www.youtube.com/watch?v=DNWKJWMKgG0
oem 15" tyre 195-50-15@30psi
your redline is almost 7
my, in this moment, whitout intake, is 6.5
your top speed 4 gear
1 50
2 100
3 140
4 180
my top speed for gear
1 50
2 80
3 120
4----
i promess this night i film a video white 16" rims 205-45 tyres and new red line
1 50
2 100
3 140
4 180
1 50
2 80
3 120
4----
16 tyres 0-160
http://www.youtube.com/watch?v=zqTMXztQHkI
is so diferent... why?
1 50
2 100
3 140
4 180
1 50
2 90
3 130
4 160
It is really weird why we have so different kmh/gear!
In what kind of road did you film the video?Because you seem to be about 20seconds slower for 0-160!...are you sure that you have 1500cc edition?
1.5 definitely
the road is of asphalt...
be doing something wrong?
No my friend,I dont think so.Your shifting is ok!
It is just weird the difference of 20 seconds we have for 0-160 acceleration..and i tested my car at a slightly uphill road.
I did it in about 20seconds and you did it at more than 40seconds!
The 1.3 2s here in greece have even "longer" fgr and with the same revlimit they have 60@1st gear,100+ @2nd gear and about 150 @3rd gear..!
I dont know what is going on but it seems that you we have different fgrs even if we both have a 1.5.
first thing coming to my mind is tyres size: have you changed rim and/or tyres with measures different from stock one? if tyre circomference has changed also speedometer should be recalibrated;
EDIT: rpm should be fine anyway, using engine main axe (I don't know correct english term here)
first thing coming to my mind is tyres size: have you changed rim and/or tyres with measures different from stock one? if tyre circomference has changed also speedometer should be recalibrated; while unsure about rpm, I mean if they are read before or after gearbox.
I have the stock dimensions..
well
last weecken, the panda see action in the drag track, 17.1, as good time for a first or second but put a bad 3th gear in the 4th pass, but I had fun and was an excellent experience
la covertura completa
http://www.msprotege.com/forum/showthread.php?t=123760426
this weekend i run in the category of novice in circuit, 1 track and 8 laps so i install back tyres traction (advan 408)
I hope I do well
sorry 4 my bad english I hope to learn
