Installshield 2
Gothenburg Superiority
Anyone interested or getting started in an FS build, you must check this out...
Mental Addiction Motorsports will be releasing a made to order bottom end assembly (rods/pistons/forged crank/and all the bearings, caps, washers, etc.) for under 2,000...and the crank alone will not be much over $1,000...
the crank is made to order, and appears to be able to be set all the way up to 94mm of stroke...obviously not what we want...but the only way to get a rod ratio of 1.60 or higher (9,000rpm for those of you confused) is with one of these cranks in an 87-88mm variety...2mm overbore on the cylinders and you are right back to 2.0L roughly...all for relatively cheap...some custom cranks can run upwards of $5k...
here is the thread...we can discuss this stuff in here, but questions for MAM should be posted in that thread...at least get in there and throw something around...I was the only NA guy in there, and I didn't find it until like page 7 or something...its a good read, just remember most of what everyone besides me is talking about is advantageous only to FI...
http://www.msprotege.com/forum/showthread.php?t=123625784
