Hi, I have been looking around google and on here to see if I can get some help but no luck. I have done all the replacing and cleaning of the usually suspect parts of having our cars lag.
The Problem: When I drive I acc and I get about 2 lbs of boost and the boost gauge still goes to about 7lbs but its like the car doesnt go any faster really. Also, when I get to a stop light Ill push in the clutch and the cars rpm's goes down to the point where the car shuts off for a split second and usually starts back up again.
I replaced the coil packs, wires, plugs, cleaned the throttle body, egr valve. Had a vacuum leak test performed and came back with no leaks. Replaced the wastegate. This leads me to think that its the MAF sensor.
Does this sound like a possibility?
Also, does the protege maf sensor work on the msp? I have crossed reference the numbers on my msp maf online and I am getting mixed answers, but the protege is about half the price and Im broke.
Thanks
Thanks
