Some discoveries/notes after driving the car to work and back over the week... some of this might have been mentioned in previous posts...
Discovered that cruise control works... winning!
A/C light wouldn't come on yesterday, but today it seems to come on and then start flickering wildly.. I think it came on fine when I got the car... I don't think the compressor is cycling with the light, but hard to tell with all the noise and vibration while driving. I'm going to try the flickering a/c fix detailed in the how-to section when it warms up a bit outside.
RPM's seem to drop off a bit when there is some electrical load.. (I start to roll the windows down, or open the sunroof...) I find myself giving it a little gas to compensate... I probably shouldn't have to do that.
One of the fog lights is out. (oh joy.)
The cup holders are designed to allow bottles and/or coffee cups to tumble out of them whenever you start from a stop. No wonder there was so much coffee residue spilled into the centre console.
I keep locking myself in when trying to exit... I've discovered my knuckles are hitting the 'lock' button as I pull on the handle...
I'm finding the 'lock tab' or whatever it's called pokes me if I rest my arm on the window opening... so I might have to modify that slightly for windows down season.
I seem to be able to get the 'vibration noise' to stop by yanking up on the parking brake... however using the brake pedal has no effect on the noise. I hear the noise coming from the passenger side front, but I suspect it's actually coming from the rear.
I think the springs in my wiper blades are a little weak...
Steering wheel shimmy comes and goes.. and ride is quite rough sometimes. Other times it's fine... I'm thinking it's the likely the winter tires... The grip on them is amazing.. I've never felt so much confidence in slippery conditions.
Rear wiper kind of stops in odd places when using the intermittent setting... I've been putting it on full and it seems to work fine in that position. When I turn it off the arm stops wherever it is, so I have to time it so that the wiper arm is in the horizontal/park position when turning it off.
Some of the lights behind the insturment cluster appear to be out.. hopefully they're replaceable bulbs and not soldered on.
