Are you sure it's a Reserve? The GT Reserve comes standard with the turbo.I have a new 3 week old 2021 CX 5 GT Reserve…non turbo.
Did an oil change on Sat 22. They updated my 21 CX-5 GTR. Hopefully it will fix the black screen. I’ll post a video of the issue later on.
Something I noticed the audio on the Bosies doesn’t sound that crispier and clean like before. I remember having this widening surround effect around the cabin and now sound more “flat”. I’ve checked all the options and they seems to be the same setting I’ve had before.
Which options have you checked? If you've already checked to make sure the Bose options are what they used to be, maybe check the Equalizer settings in the infotainment as well.
Hmm, just checked my 2021.5 CX-5 Sig and it is on 11026 with no downloadable update available it says. What's up with that?!Did an oil change on Sat 22. They updated my 21 CX-5 GTR. Hopefully it will fix the black screen. I’ll post a video of the issue later on.
Same here. Has anyone successfully done an over the air update on the system? Wouldn't be surprised if despite claiming to do over the air updates it's still something the dealer needs to do for you.Hmm, just checked my 2021.5 CX-5 Sig and it is on 11026 with no downloadable update available it says. What's up with that?!
In this case your dealer is incorrect. I updated mine at home a couple of days ago. Current version is 11038 so you do have an update available. Mine was at version 11022 when I started for a car purchased in 5/21. I do not notice any difference in the sound quality from my Bose system.Just had my 21 CE 2.5T in for a TSB (ECU update for cold weather acceleration issue in cold temps) and I asked them about updating the infotainment software. They said there wasn't an update available. I trust the dealer and they've never been wrong in the past. Not saying there isn't an update out just sharing what I was told. Maybe the OP is from a different region or something. I'm in the US and my software version is 11026.
I've been having the same periodic repetitive restarting as well. I'm currently on 11026. Please keep us posted on whether the update fixed the issue. I was using an Amazon purchased nav SD (which is known to cause the restarting) but have taken it out and the restarting issue persists. Thanks and good luck!My 2021 Signature was just updated at the dealership to 11038, OTA indicated no update available. My system periodically reboots while driving. Hopefully this is the fix.
So please tell us how you updated yours at home. OTA does not seem to work,In this case your dealer is incorrect. I updated mine at home a couple of days ago. Current version is 11038 so you do have an update available. Mine was at version 11022 when I started for a car purchased in 5/21. I do not notice any difference in the sound quality from my Bose system.
