Here's an update everyone!
Haltech is still in the works, coolant neck with temp sensor port is welded, just needs to be cleaned and painted. Section of intercooler piping with flange for bov and IAT sensor bung is all done and welded, just needs to be re-polished. Had Brian Lawlor build me a valve cover with the mounts for toyota 1zz-fe ignition coils, all shaved and nice, powdercoated in silver vein.
Had a bad front knuckle that had came loose and wobbled out around the lower balljoint, so i decided to stock up and completely refresh the suspension, changed some things to allow for better wheel fitment as well. Stock front lower control arms with Superpro Poly bushings, Brand new oem steering knuckles in the front, new wheel bearings, hubs, axles and replaced the arp studs with new ones that i had. Reached out to YellowspeedUSA for a new set of threaded strut inserts for my coilovers, but this time valved for stiffer spring rates... much stiffer spring rates, 24k springs front and rear!
Other things are: I made a gloss black vinyl windshield visor/banner, because I removed my interior visors to put in a 5 panel mirror, Installed a purple underglow kit (haha, a joke at first, but it really grew on me!). Replaced my glowshift oil pressure gauge with an AEM unit. Got my hands on an oem nardi airbag for my nb miata nardi wheel. And am currently working on an h1 projector retrofit in a set of P5 headlights!
Car is dirty at the moment, so no photos of the outside yet, but heres a teaser shot of the fitment! Still my daily and only car!
