does anyone have the j-spec motor installed on their car? im thinking about doing this swap and was wondering how hard or easy it is to do, and if there is anythng crazy that i need to do.
i think all you gotta do is get different pistons, intake manifold, and cams. corksport sells all those. probably cheaper than getting the fs-ze. i could be wrong though. if you did swap, i'm guessing you'd have to get the j-spec ecu as well.
do a search this topic has been covered many times, thus it would be cool, if you could some how get there ecu to work, but it really isnt woth it, unless you want to go for JDM factor, but you would be in a lot more then most turbo kits once done.
