yeah there are more differences, i just didnt take the time to put it in.
heres a quote form the protegefaq, courtesy of theMan:
" There are none for the 1.6l (ZM) engine. 1.8l (FP) and 2.0l (FS) owners can swap
in the JDM FS-ZE's intake manifold to help improve top end performance. The
FS-ZE's intake manifold has some basic resonance tuning due to the addition of the
resonance chamber bolted on top of the runners (it is actually connected to the
plenum log chamber). Several modifications to the vacuum line routing will have to
be performed when installing the FS-ZE intake manifold to either of the US spec
engines. First, the FS-ZE's intake manifold does not have a fitting for the boost
sensor. Also, installing the intake manifold on a normal Proteg 2.0l (and 1.8l CA
spec) will mean the loss of the VTCS emissions control component. Intalling the
intake manifold on a "48 state" 1.8l Proteg and a MP3 will not have this issue.
The intake manifold found on the stock 2.0l and 1.8l CA spec Proteg's have the
VTCS component designed to control cold start emissions to help achieve the ULEV
emissions standard. This same system also causes some minor restrictions and air
turbulence in the intake manifold runners. Changing out the intake manifold to one
that does not have VTCS will offer some minor performance improvement however
the vehicle will no longer be emissions legal. The intake manifold from the "48 state"
1.8l Proteg and the MP3 does not have VTCS."
