- Canada
Just had the same problem with three of the corners had spider cracks. Dealer replaced it no charge under warranty with 5 days left on bumper to bumper warranty. Invoice did not show cost. However, new unit screen is different, with vertical black bars about half inch on both edges. Effectively making the screen size smaller?
@PapaJoe What year and trim level is your car, and what region are you in? Does the invoice show the part numbers of the replaced components?
You can google the part number (if you have it) to see if it is a direct replacement for your model year and trim. If the screen appears to be smaller now, the only thing I can think of is that they replaced your screen with one from the base trim level. For 2020 models and older, the base model gets a 7.0" screen, while other trims get a larger screen.
