lazybusinessman said:you need the metra kit to do so. after you install an aftermarket stereo you can change the text up top up to 10 letters i believe.
chuyler1 said:x3, You didn't say what car you have. Just as an FYI, the Metra kit is not compatible with the Mazdaspeed6. It only works with a regular 6.
DPSpeed said:Not anymore, they have fixed the 99-7507 kit and it now works with the speed6.
src666 said:Now that you have your hands on the 7507 kit, how do you find the fit & finish?
src666 said:Other than the lack of the chrome edging, how is the color match?
src666 said:Also, do you know if the panel on the stock MS6 has a different finish/texture than the 06-07 6i/s?
DPSpeed said:My kit is actually a 03-05 kit that I had painted last year to match the dash. The 06-07 kit is exactly the same as the 03-05 kit except it's more of a darker gray color.hat
chuyler1 said:How did you match the speed6 paint?
I took off a piece of the dash trim (the piece above the coin box) and gave that and the kit to a local body shop to match. How he explained how they did it was to paint it black first, then silver. While the silver was still wet, he used a fine brush to bring up the black streaks through the silver. It took him about 3 tries before he liked what he saw. Then it was clear coated. He did a great job, unfortunately he has moved to Florida somewhere.
