Project halfway complete!
Only part that sucks is the FIRST bolt i bolted in cracked the plexi :/ but it's only an inch long so i'm going to drill a small hole at the end of it and seal it up.
After placing the plexi in the rear didn't match up the way i wanted it too, and was bound to leak and made the roof sag a bit. So I went to the store again and found some roof edge.
This piece was about 10 ft. long so I had to figure out how to cut it.
Well i'm at the hardware store! So i asked an employee where the metal shears are and their tape measurers and they were right next to each other lol. After being stared at by an employee as i'm measuring and cutting this 28" piece I put the tools back and purchased my items.
I put that piece of roof edge on the rear and used the weather stripping i purchased to seal it up in the back.
The sheet metal screws held the plexi down much better than i thought.
I put a real thin layer of silicone before i slapped the glass on and went to work
I drilled pilot holes before i drilled with a smaller drill bit than the screw so it ended up beign a perfect seal and getting a real nice bite into the plexi and the aluminum..
I would've loved to have taken pictures of the entire process but I was alone when i put it all together and i couldn't stop to take pictures when i'm waiting for silicone to settle. But i took after pictures!
Here is what it looks like as it sits
Here's the nasty roofedge that i'm going to trim down after the silicone cures.
Heres the crack :/ This was my first bolt i put in. Every bolt after that was put in very carefully. (Good thing I opted to not go with rivets)
After some research, I found out that I can actually stop that crack and just seal it. (I'll probably just put a sticker over it after i seal it)
I Just siliconed the living hell out of it. I put in so much silicone that i'd be surprised if it even leaks. I actually have some left over so if i missed anything i'll seal it and if it leaks again I can just keep siliconing it!
The only step now is to cover up my mess..... One more trip! I'm thinking of going with garage door bottom, but Who knows what i'll run into.
I might even put some LED lights up there lol but probably not because those are hella played out now.
Tommorrow i'm going to town with a hose and simulating the worst rainstorm that has ever hit california.
