[/B]The CX-9 does have some good points:
1) It handles very good for it's class. ( Why I bough it ) Absolutely
2) It rides good and is reasonable quite. I do not find the 20" wheels to be harsh as some thought. Slight jiggling, extremely quiet
3) The Bose sound system is excellent. Yep
4) There are plently of tye-down hooks in the cargo area. Never use them?
5) I Think it looks good... Subjective, but I think best in class, with the GM ones a close second
6) The climate control system work quite well. No complaints
7) I like being able to slide the second row seats Forward for more cargo room. Really designed to give 3rd row passengers some legroom
However, there are many negatives as well:
1) The engine is quite weak off the line. It pulls hard in the mid range and then dies off in the top end. This makes merging with the high speed Atlanta traffice difficult. It is difficult to pass. Basically it needs more HP and torque to move it's hefty mass. The new 3.7L for 2008 should help some... Have not noticed any lack of power in any situation?
2) Even though it is a big vehicle, it's usable interior space is quite limited. Mazda should have done a better job at giving you more storage inside. The single console box is quite small for this class of vehicle. Depends if you are a pack rat I guess, try a plastic box under the seat if you have that much junk?
3) The rear seat is too low to the floor making it uncomfortable on long trips for adults. I also do not like the rails in the floor that you see infront of the rear seat. It is hard to keep stuff from falling into the cracks. The rear seat is low for someone with long legs, but almost all cars are that way?
4) You cannot lock the doors until all of them are shut. This is VERY annoying. You have to stand and wait for everyone to get out and close the door before hitting the lock switch. The door locking/unlocking logic of the three outside switches is a little silly. You cannot open the rear hatch with the FOB or rear switch until you unlock it. However the rear switch will lock all of the doors if ANY doors currently unlocked the first time you press it even if the rear door is currently locked. Haven't noticed an issue locking and having to wait, but yes having to unlock all the doors before the hatch opens is really stupid
5) My knee hits the center console and the dead pedal foot rest is almost under teh brake pedal. I guess it is because the wheel well protrudes so far into the cabin. My knee touches the center console too, but I forget about it in a few minutes, haven't noticed the dead pedal being in a ackward position
6) There is a LOT of wind noise near the top of the driver and passenger door at highway speeds. I don't think there is lots of wind noise, I think the car is so quiet that the only noise you can hear is the wind on the roof rails
7) The mirrors shak a lot while driving. It is a little annoying especially when there is a light reflection in the mirror. Mine don't shake at all?
8) There is a bad blind spot one each side of the vehicle. You really should add a little round mirror to the side mirrors. Mirrors properly adjusted and no blind spot?
9) I hit my head on the rear lift gate ( 6'-4" ) I am finally learning to duck...But it clears the garage door when open inside my garage
10) There is very little head room for me even with the seat all the way down and tilted back. I have plenty of headroom with no unusual seat positions and I have the sunroof?
11) The navigation system is pathetic. It's map is very outdated. It is difficult to uses. I have a little Garmin Nuvii 330 and it is far superior in just about evry way. You CANNOT use the Nav system at all when driving even if there is a passenger in the vehicle. The Rear view cammera is nearly usless as it's prespective is very distorted. I rarely use it...Other than not being able to enter a new destination while in motion (very annoying) it works well, and the back up camera is meant solely to check that you are not running over something in the blind spot behind the hatch and it works fine for that?
12) It does not come with cross bars on the roof rack??? Don't know what you use the roof rack for, but I have to use Thule crossbars for my Thule box anyway?
13) The carpet is very cheap looking and very thin. And you can get any color you want as long as it is black...Oh please
14) The second row seats do not fold completely flat...You are right
15) The sotrage area under the rear floor is very small. The one in my little 2005 Marinere was bigger. Subjective, it plenty big enough for what i use it for
16) There are NO side cubby holes in the rear at all??? ?
17) It does not get good gas milage. 15mpg-18mpg is about all it will get in real world driving...Got 18 MPG on the very first tank in mixed driving and 22 MPG on the first 75 MPH highway run?
18) Uses the little 1-1/4" towing hitch. I know it is rated for 3500lb, but the 2" is much more versital and there are many attachments that cam make use of it for thing like bike racks. True
19) The seat heaters are simply on or off. They pulse on and off making it too hot and too cool at times. WOuld Low, Med, High be too much to ask in a 40K vehicle??? They are stupid, yes
20) There is no trip computer. ( really minor issue ) But I would like one, can't beleive they skipped this
21) The rear glass does not open so you have to ope the hatch more often. I wonder how long the auto hatch will last... Big deal
22) The Manual shift feature is nearly usless. There is nothing sporty about it. There is a long 2-3 Second pause before it will upshift or down shift when you flick the lever. The only thing I can see it will be good for is holding a lower gear to slow a decent in hilly areas. Manumatics are useless on every car that has them
