float_6969
- 2003.5 MSP Blue #2450, 1995 Nissan 240sx, 1996 Mazda Miata
So my oil consumption is really high. Like a half a quart every gas tank. Plugs aren't fouled, and no oil leaks. Smokes bad when you first start it up, especially when it's cold (like sitting overnight). Due to the clean plugs, I don't think it's burning it in the combustion chamber, which means it's either the exhaust side valve stems or the turbo. I don't think it's the valve stems due to the fact that it wouldn't be going through oil as quickly as it is.
So if I'm right, where do I find a new center section? I'm not interested in upgrading the turbo, as I'll never want to make more than 200hp. This is the DD and I don't want to get to crazy with it.
If I can buy just the center section, can I replace it without having to remove the manifold and turbo?
If I do have to remove the manifold, I want to replace things that require the same things to be removed. The stock manifold is cracked in 2 places, but doesn't seem to be leaking. Is it going to leak eventually, or do the cracks seem to stay the same? They've been there since I bought the car and haven't changed.
Does the stock "S" pipe need replaced for the power levels I'm looking at? What about the "J" pipe?
Any other things I should do while I'm in there?
