GAr... I haven't looked back at this thread in awhile. Been too distracted with multiple computer related and vehicle related issues (yay).. and pending snowboarding trip (YAY)
1st MP3 in NH said:
I think he was callling BS on Ben saying that being near redline in 2nd wouldn't be an issue. Also I fail to see how he is being arrogant.
Not to mention he obviously knows the basics, atleast more then alot of people in the turbo area so being a junior member should restrict his comments any especialy of that nature.
1st MP3 in NH: thank you for at least a benefit of the doubt (I think?)
LinuxRacr said:
There could be a missunderstanding in the midsts here. Hmmmm
LinuxRacr: I wasn't trying to attack you or anything, in fact I've met you once (at the Mazda6 gig down in Houston). We have a common friend... (ooh, I love suspense!)
Anyways, yes, that was aimed at Ben. I was quoting LinuxRacr to try and clarify why I was calling BS on Ben, but I supposed I should have added something along the lines of "since LinuxRacr said THIS..." to clarify that. Kinda shot myself in the foot with that attempted clarification..
And yes I haven't been a member here long, tho I've off and on (mostly off) read various protege boards for awhile, mainly because one of my best friends owns one.. I don't know as much about them as say I know about my car (240SX) and most that I know about the Protege I've picked up as third-hand knowledge..
big_ben said:
Ok, I'll explain it for people that don't understand. Being in full boost at redline in 2nd gear and being at full boost near redline in 4th gear are two greatly different things. The gear ratios in 2nd gear are MUCH more forgiving and there is MUCH less resistance to the engine. Being in 4th gear underfull boost is MUCH more stressful on the engine. The engine is being held back by the gears and there is TONS more resistance on the motor when in higher gears. This guy sounds like he knows a little of what he's talking about, but if he didn't know that, he doesn't know much at all. So there is my bulls*** flag.
Ben: True, higher gearing has higher resistance and is also why you can build boost faster in a higher gear. But just because you add some more resistance in higher gears, that doesn't mean you're not still putting a lot of stress on the engine. In fact, that resistance is really not that important.. 4th may be half the ratio of 2nd, but in the big grand scheme of things the drivetrain resistance doesn't make much difference - Now, if you were trying to accelerate instantly from a stop (clutch dump for example), it would require the engine to do more to reach/maintain the same amount of rotation, but we're accerlating while already moving, so we're adding small amounts of velocity, not huge instantaneous driver-debilitating clutch-destroying chunks of it.
MOST of the stress (nearly all of it) acting on the rod is from the compression it undergoes during the combustion stroke, from the cylinder pressures compressing the piston and rod down the crank, and as the crank turns the slight (altho still significant) sideloading of the piston (and therefore the rod) on the cylinder walls... it'll pick up stresses from the intake stroke as well (as the crank pulls the rod down and the suction of having to pull in air causes the rod to be pulled apart), along with the compression stroke (compression stress just like combustion stroke) as it forces all the air and gas to be REALLY FRIENDLY, and of course the exhaust stroke (pushing the exhaust out of the chamber).
Now, allmost all the stress is in that magical (hopefully well manged i.e. no detonation) explosion of the combustion stroke. If you bring in detonation, you now have (big) little extra jolts of force acting in places they shouldn't at times they shouldn't, pushing the piston (and therefore rod) in ways they're not supposed to. And if its REALLY BAD, like too far before TDC, it'll be like a head on collision between the detonation and the piston/rod assembly. Now imagine doing this say, 60-70 times a second. thats like taking a jackhammer to the rods (which unfortunately, being the monkey in the middle, and often weaker than the piston (in terms of how much abuse can be taken), must often be the component to deal with the bulk of these stresses). Maybe more like a jackhammer to a peice of iron on top the rods, but hey..
ANYWAYS.. point is: No matter WHAT GEAR, the higher the revs, the more the stress. Higher gears will increase stress, but by a far smaller (and nearly inconsequential, when vehicle already moving) degree than higher engine speed.
ALSO, just to make sure you got what my previous post was basicly saying: it WASN'T because he was WOT 2nd that killed the rod - it was merely that this particular time of WOT 2nd was all it took to break through what was left of the rod's structural integrity. Most of the damage was done while detonating under boost most likely, which makes for rediculous amounts of stress.
Keith@FP said:
What kills rods? Detonation, aka knock. The Protege rods should be strong enough to handle 6 psi of boost easily. However, if they've been bent or damaged from persistent knock then they'll eventually fail. I suspect that's what has happened here.
See, that's what I was saying
Now for the rods: Yes, the stock rods are probably good for more than stock, but not when detonating. chdesign mentioned Mazda rating the stock as good for 225whp (which means they can probably take more in a well tuned environment), but if you introduce prolonged detonation, you can break or permanently weaken (to the point of breaking, making it inevitable) things at much lower levels, and VERY FAST.
Also, keep in mind the FS motor has a rather craptastic rod ratio of ~1.47, IIRC. That doesn't help with detonation resistance at all, but does help with torque. For comparison, a SR20 for example is ~1.58, and FE3 is ~1.74. Higher is better (altho less torque, more resistance to detonation & etc and also better peak power due to better high end breathing (which is why its worse at low end - worse low end breathing)) .. ususally 1.9-2.2 for endurance motors.
Here is a good page I've found that does a good job of covering rod ratios, for those inclined to find out more. It's a domestic site, but that doesn't really matter much, the underlying principles are the same (and smaller displacement motors can more effectively / safely use higher revs, than larger displacements).
Now if I could just figure out where I read formula/statistics for stresses under detonation vs boost.. I recall having read (site or a book, don't recall) something that illustrated how detonation is far more damaging than boost..
To those who bitched that or implied that I don't/can't know anything having been here for a short time... BAH!
I'll admit I've only had an interest in cars for a few years, but I have picked up much, and keep trying to pick up more. I will admit I'm not most familiar with the Protege engines but some things can be carried across all makes.
Now for that suspense: I arrived to the Mazda6 event in LinuxRacr's and myself's mutual friend's metallic silver-ish Protege (I don't recall the exact name, unfortunately). Some of you can probably guess who it would be, I hope LinuxRacr can
*puts on the Nomex underwear*
