So Today I decided id check my compression since I plan on getting supporting mods and a fmic and eventually push more boost, if everything turns out good. I took out the fuel pump relay or whatever you want to call it (fuse) and pulled out the ignition coils and the plugs, I only pulled one spark plug out at a time though and checked each cylinder then replaced the plug and moved on, and so forth. I cranked each one over for roughly 3 seconds each, as close as I could get it to being the same time. well all cylinders are 175-180. they had a real tight pattern and I was pleased with the results! put everything back together and went inside. came out to drive it tonight so it sat roughly 7 hours. started it up and ran back in the house to grab a water and walked back to the garage and noticed a little smoke rolling out the garage door, I gave it a little throttle and it smoked more. after I examined it I decided I was going to take it to the gas station, got there and it had stopped smoking. so I went to town ( 20 minute drive ) got to town went in a store and came out and started it, I let it idle for a minute or so and revved to about 3k and got out and more smoke. drove 1500 feet and smoke was gone. what could this be??? My poor msp has had a rough past couple months
