Hydra install:
I decided to install the injectors and the O2 sensor before the rest of the Hydra, as I was unsure if
Yesterday I installed the 700cc injectors. I don't have any pics of the install itself as my hands were too dirty to use my tablet camera.
Then on to the O2 sensor. I spent a bit of time hunting for where the front O2 plug is, and finally found it tucked away on the OEM manifold. Took about 5 minutes of figuring out the right combination of tools to get the leverage needed on it, and it broke free and popped out without much fuss. Installing the WBO2 took much longer as I was having trouble getting the threads to engage. (If you are asking yourself if something is wrong here, just keep reading) I got it installed:
Next I moved to the top of the install instructions for the Hydra itself.
Running the adapter cable itself was a pain, lots of delays and frustration, as the prior owner ran the added electronic wiring through the only available passage from driver's side to passenger's side, so lots of obstructions:
I got it though:
Through the work, my car-mounted tablet stand was very handy, having access to the instruction PDF as well as forums and searches, etc...
Lots of stuff to pull out of the way behind the glove box, as the prior owner mounted the FM transmitter there, along with other wiring. But, the money shot?
I had about 4 feet of vacuum line from the FM O2 signal modifier that I had just coiled up and zip tied out of the way, so I removed the FM O2 mod, uncoiled that line, and passed it through to the Hydra. Already T'd into the boost gauge vacuum line. without leaks.
I ran the WBO2 wiring for the Hydra through the same firewall hole that I had used for the O2 mod:
It was shortly after this that I took a break for dinner, and SMR pointed out something I missed:
If you have a FM turbo kit there will be an extra bung for the WBO2 already in place in
the downpipe just before the catalytic converter. If you have something else, you will need to
weld in a bung- we have them available. Make sure the sensor is as perpendicular as possible
so that condensation does not pool in the sensor tip. Also, the WB needs to be after the turbo
(or after the collector on non-turbo cars) and still in front of the catalytic converter.
So this ground me to a halt. I have the FM2 downpipe which will give the O2 a proper location, but that will require installing the FM2, and I'm simply not ready for that. Not enough time before my track event to make sure there are no remaining bugs.
My options are:
1 Run with the narrow band, and just make sure it's pegged full rich on it's scale. (theoretically safe)
2 Same as above, but lock out closed loop, run open loop only (costly in gas, theoretically safe)
3 Pull the downpipe and get a bung welded in for a few weeks (annoying)
4 Re-install the OEM injectors and swap back to the OEM ECU until I do the FM2 install (really not looking forward to that)
I'm thinking #3 is the right choice.
Will be talking with FM on Monday when they open, and my tuner on Tuesday when they open, to discuss the options and recommendations. Pretty sure they will both tell me #3.
I'm not resisting the "right option", just want to make sure it really is the right option.
Today I'm going to continue with the Hydra install, including wiring the WBO2 into the Hydra, just leaving the sensor off the car and unplugged, so I can just plug it in when the time comes. Shouldn't take more than an hour of work left before I can apply power to the Hydra and start going through the pre-start list in the instructions.
Will update later today.
...and I successfully snagged a FM stage 2 fan pack from another member here, so will be doing the crossflow install next weekend.
