I just finished installing the "Big"U.S. version strips onto my Canadian MP5. Now I have somewhere to tie the Dogsled to.
I traded my stock "Flush style"Canadian strips straight across for the U.S. version stuff with another board member,...it all went very smooth,...thanks again for this detailed "how-to" thread.
I would like to add this,...there are 5 "clips" glued into the bottom of EACH roof rail?troughthingy on the CanadianMP5,...you must remove the back 4 clips on each side to make room for the U.S. style strips, mine came off unbroken by using a thin edged straight screwdriver and a couple of gentle taps with a hammer,...LEAVE the front two clips(one on each side) in both the U.S. and Canadian cars.
I removed the 4 "roof rack mounting brackets"(2 10mm nuts each), and sent the whole collection to my U.S. friend.
Altogether I sent the 2 strips, 4 brackets/8 bolts, and 8 plastic clips along with the measurements of where my clips where installed in the roof troughs.
On my install I had to drill 3 holes in each roof trough to accept the U.S. parts,...my U.S. friend will have to glue(I would think that epoxy would work well) the clips into position.
I duck taped over the extra holes in my Canadain MP5's roof troughs.
NOTE: If you never intend to use the "aftermarket" Mazda roofrack that us Canucks are supposed to buy(?!)(read:expensive?!) then you do not have to install the 4 roof rack brackets that are hidden under plastic covers on the Canadian roof strips,...
In other words you can just cover the holes in your U.S. MP5's roof and reinstall your headliner/interior,....when your Canadian fill strips come you can just glue the clips into place and when dry clip on the strips,...this can save you the work of disassembling/reassembling your U.S.MP5's interior twice.
If the above is true I can make this helpful suggestion. If the "Yank" removes his/her peices first and sends them to the "Canuck" who then removes his/her stuff then sends it to the U.S. partner then BOTH parties only have to disassemble/reassemble their interiors once,...(remember,...the "Canuck"has to unbolt the 4brackets to allow the U.S. rack pecies to fit.)
