Hey everyone. Normally i'd take my time and check into things like this, but the situation is that my sister is buying a 2002 P5 w/ 160,000km on it and will be picking it up next week (she lives in another city). In the meantime, I need to change the timing belt (done it before on my wifes' P5), diagnose a non-working rear wiper, and check into a front end clunk.
Can you help me out so I can save some time?
Rear wiper issue
The rear wiper does not work. There is no noise from the rear wiper motor when the switch is "on". The wiper is stuck about 2-3" above the normaly resting position.
Is this the motor (I've heard of these going bad on the P5 -- plastic+metal gears don't mesh when under tension!).? Or is it a seized arm, etc? How do I check this systematically?
Front end clunk
There was a distinct front end clunking noise when I test-drove the car. The car passed a safety but the mechanic who safetied it for the seller said that the front struts "might be bad but it's not part of a safety issue". I've also heard that the front swaybar endlinks are a very common source of clunking noises when going over bumps and manhole covers, etc. How can I check both of these, and possibly the balljoints, to try to diagnose and then fix the problem before my sister gets the car next week? On the test drive, the car drove very well and felt nice and tight, but the only problem was this noise.
Thanks a lot everyone!
Eric
Rear wiper issue
Front end clunk
Eric
