Hey shiesty,
does the sirius tuner use the cd changer connection? If not, I would just get that aux adapter that I was talking about. I doubled checked and as LEXi73 said all you have to do is plug it in, no adittional settings are required.
Hey LEXi73,
Yea, there is a RCA adapter that connects to the iPod dock connector. It is sold at
www.circuitcity.com. Here is the link:
http://www.circuitcity.com/ssm/Nyko...26333/catOid/-14781/rpem/ccd/productDetail.do
However, they seem to be out of stock at the moment. Using this cable should eliminate the need for volume adjustment on the iPod. I'm pretty sure that it is basically a pre-out, so any volume adjustment would be done on the headunit. The only problem is that you would not be able to charge while using this cable.
There are some crappy docks out there made by a company called DLO that use the dock connector for sound and charging. The dock has a miniplug output on the side of it for sound output and the dock plugs into the lighter for charging.
I initially bought one of these, but returned it 10 minutes later before I even left the parking lot. For several reasons:
The docks were designed to be universal, so if you have one of the new video iPods, it is too thin and will flop around alot on the dock connector (not good!).
When charging and listening to music, you can hear distortion from the lighter (very annoying!). It sounds like a ticking. If you use the audio output on the dock without having it plugged into the lighter, the sound is great and iPod volume adjustment is not needed.
I believe the cable I was talking about above would give you the same sound quality, eliminate the iPod volume adjustment when connected and you would not have to spend money on a crappy fitting dock or a distortion generating charger.
