Hi All,
Hoping you can help. I purchased a wheel mount bike rack to go along with my CX-7's Class III hidden hitch: http://www.etrailer.com/pc-H~87421.h...cleid=20077499
Here is the bike rack I bought: http://www.etrailer.com/pc-br4b~S64665.htm
I have one problem. I can't fold the rack up as it's designed to do because the CX-7's bumper gets in the way. Therefore, I need some sort of hitch extender.
The rack weighs somewhere between 55 and 62 pounds. I used a bathroom scale to weigh it, so it's hard to get an exact measurement. It comes out from the hitch about 4 feet or so.
Here is the extension I plan to purchase: http://www.etrailer.com/pc-EXTENDER~HE06.htm It adds 7 inches to the length of the base, so we'd be looking at closer to 4.5 feet from the back of the hitch.
Etrailer stated that if you use an extender for your hitch, it decreases the tongue weight by 50%. They also stated that the tongue weight of my hitch is 350 pounds, but that I should be looking at the tongue weight of the vehicle as well. I'm not sure how accurate it is, but I've seen websites that say the towing capacity of the AWD CX7 is around 2000 pounds. The tongue weight is typically 10-15% of the towing capacity, so that puts us at around 200 pounds.
So, if I have to decrease tongue weight by 50%, it's 100 pounds for the car - or 175 pounds for the hitch.
I figure the total weight of the bikes and rack will come out to about 175 pounds (60 for the rack and 115 for the bikes).
I'm nervous no matter what, but I'm not sure I should be. Is tongue weight really only a problem if we're talking about towing something? Is there reason to be concerned that I'm: 1) going over the hitch's max tongue weight (if you decrease by half due to the extension), or 2) going over the CX-7's max tongue weight (if you decrease the 200 pound estimate due to the extension)?
What could happen if I add a 7" extension to this hitch and then have 175 pounds worth of rack and bikes attached to it?
Any further thoughts here? Anyone had this problem before? Thanks again.
