John at J&S
Power required in cranking as well as run. The power wire to the coils is a good choice.
Pirana said:Quoted from Juan at HiBoost in a previous thread...
Perfworks,
If you are talking about a T3 not any hybrids T3/TO4B or TO4E, the IHI has a larger compressor than the largest T3. There are many F5s available. Our turbo has the largest. (48.5mm) Compared to the largest available from Turbonetics the Super 60 which in fact is an exclusive Turbonetics compressor wheel of 48.2mm (1.90 Inch), the ihi is a bit larger.
On the turbine side, ours has a 20Z turbine which is aprox to a 0.71 A/R in a garrett size.
If we were to compare our turbo with a garrett, it would be the following:
A hybrid TO4E/T3 .46 TO4E on the compressor with a 0.63 stage III turbine.
The big difference is how fast both turbos would spool. I can say the IHI will make it at least 1500 RPMs sooner.
It is not just the physical size of the turbo what matters.
Juan
__________________
HiBoost Turbo Systems, Inc.
info@hiboost.com
www.hiboost.com
260 WHP @ 14 PSI
13.8 @ 105 MPH
you should have power cranking and the on position onlyLittle Beavis said:Does Pin 71 have power even while cranking? Do I need it to?
Woohoo! Safeguard here I come.
John, the wife says it has arrived. . .yippee!
perf...with that amount of boost, how you manage to keep the tires in the street?...cause' i remember @ 7.5psi 2ng gear has a tendency to break loose...a lot of wheelspin even with the stock clutch slippinMy T3T4 spools to 5psi at 2800rpm. 13 psi by 3200rpm and full boost last week at 18psi at around 3400rpm
with the stock differential it is hard. it wants to pull to the right.igdrasil said:perf...with that amount of boost, how you manage to keep the tires in the street?...cause' i remember @ 7.5psi 2ng gear has a tendency to break loose...a lot of wheelspin even with the stock clutch slippin
Darin said:You should research the bikes you claim to want soooooo badly.
A stock R6 puts about 100hp to the rear wheel...a stock R1 about 140.
(shrug).
nice list of rides manSR20DET said:So how much boost were you guys running and how much WHP were you putting down for that 13.8 run in your sig ?
