Hello,
Here is my dilemma. I have a 03 protege sedan, that has the upgraded, racing beat sway bar, awr adjustable endlinks, axr clunk fix bracket with the energy suspension bushings. Aslo using tokico blues/ hp with eibach pro kit.
I have had the tokico and eibachs on since i bought the car new, i have 41000 miles on it and never had noise from them. Once i got the racing beat sway bar i got that clunk but the axr bracket fix that, now the clunk has come back and worse then ever. Sounds like the strut is broken.
I have been under that car and tighten everything up, from the new brackets, bushings, endlinks, top of the struts under the rear deck and nothing is loose. Any other suggestions on where the clunk might be coming from and solutions on how to fix this would be helpfull .
Aslo if it does happen to be the struts what are peoples opinions on a set of new struts. I am currently looking at the tokico illuminas or the green mazdaspeed jdm struts. i've read through a lot of forums and a lot of mix reviews on these two sets.
Thank you for reading through this and hope to get some feedback.
