Palomatic,
This is as close to a detailed install as they get. http://www.theretrofitsource.com/pdf/trs_tech/Morimoto_Elite_HID_AMP.pdf
It's really quite easy to install them. On the passenger side you can get access from above without having to take anything out or apart. The driver's side simply needs the pop-its removed from the wheel well liner and the well liner to be peeled backward and inward to access the headlamp connections.
