Somebody tell me how to fix this issue. Been reading about it on the forums here but i can't seem to fix it. Maybe its the speed sensor but idk. Any how to's on this issue here?
Right rear wheelspeed sensor is the most common cause. So common that I am sure this is the problem. You can pull the code which will confirm this. You can also swap the left rear sensor with the right rear in order to check as well.
