Hey All.
Looking to pick the brain of the gurus that understand engine controls better than I.
Specifically, trying to get a handle on the readings from an oxygen sensor, what they should be, and how that impacts other stuff.
Background: Recently had a coil pack go bad on me, and had to limp home on two cylinders. Predictably, Im now getting the dreaded P0421 code. I have an ultragauge, and just clear it as a pending code. Inspection with emissions is due in a couple of months, so trying to see what I can do to fix it other than replacing the precat.
The ultragauge lets me check fuel trim and also the O2 sensor readings. Front and back start out around the same, but the front seems to bounce around a LOT, and Im curious if perhaps I killed the sensor instead of the cat (140k on the car, sensor is original). Should the front reading be higher or lower than the rear sensor?
Any input here is much appreciated. Would be good to know before I start buying bits and pieces if I can just buy a sensor and be done with it....
Thanks!
Thanks!
