traitorhound
powered by FLIP
hey guys,
i was installing my DEI alarm (hornet 564) and i have everyting wired up correctly and everything works except for my power locks. (dunno) i have had everything wired up as according to the relay diagram into the sticky. but stupid me when i was hooking up the power wire it shorted to the dash and sparked and whatnot and now the doors do not lock at all except when using the oem keyless remote (the door lock switch on the drivers door doesn't lock, unlock works fine). the unlock switch works fine on all methods, oem keyfob, alarm remote, and door switch. is there any place i should look at to find out what i broke and need to replace before i try to do this thing again?
i took the switch out of the door and used some wire to short the 2 connections and it unlocks the door as it should. when shorted with a 1.5k resistor it doesn't do anything meaning i did mess something up internally. i checked all the fuses in the drivers kickpanel and everything seems to check out so i have no clue
man i have spent like 20 hours on this damn install and everything is nice and perfect except for the damn locks. . lol i had no problem with the remotes start module and all the other wires. . just the damn lock wire
any help will be greatly appreciated
rich
rich
