Hey guys I hope you're in a better state than I am.
Firstly:
Two nights ago my 02 tiptronic hit a hole in the road and the engine died.
It restarted OK in neutral car reved out to 6K rpm just fine.
Engaged drive, gradually increased throttle when it gets to 1500rpm the engine bucks, battery light flickers and car shuts down.
Ok, so I kept the revs under 1500rpm drove over a bump in the road, same thing happened, engine bucks, battery light flickers and car shuts down.
Secondly:
I noticed if the car is in neutral and rolling, slamming the brakes suddenly creates the same issue, battery light flickers and car dies.
Checks Done:
Pulled a Cam Shaft snsor error code from ecu, and replaced with new sensor.Same issue.
Reseat all cables in engine bay. Same issue.
What next????
Any and all responses are most welcomed
dre
Issue Solved: see post #7
Firstly:
Secondly:
Checks Done:
What next????
dre
