My car overheated and sprayed coolant all around the overflow. I fixed the overheating problem by changing the thermostat.
Now both my headlights are out. The high beams work. Just the low beams/running lights aren't working. I have checked the relays by swapping the headlight one with the working horn and rear light ones, the fuses in the fuse box look intact and I checked with a new bulb.
Also, the heater/defrost fan only works on the highest setting now.
Any ideas what else I should check?
