JoshP5 said:If you want quality replacement bulbs get Osram H7s. They're available here.
Brian MP5T said:They are 3 times the cost and are not built any stronger or durable than regular.
They claim to have a better output, but tests have proven that the wattage is the same and the lumens are the same, the only diference is a mild blue coating on the glass that makes the light seem white-ish
mauibuilt said:Should the wattage not be the same? If you put in a bulb with higher wattage your asking for problems. And these silverstars are brighter than stock bulbs.(shocked) You life in Canada Brian MP5T, go to Crappy Tire, they have a year warranty on these bulbs. I must say they don't last long, but I think that's the P5's fault
mauibuilt said:...I think that's the P5's fault
