Forced_Firebird
I seem to be having a shaking issue with a '01 ES. Installed a turbo last week, been driving fine, now at idle it appears that the damper is vibrating pretty and and the belts are squeaking.
My first thought was that the rubber section on the damper may have been on it's way out, but I put the car up on my lift, pulled the wheel and used a pry bar between the damper and oil pan lip and it seems solid. When the engine is revved, the vibration goes away (only at idle).
Codes being set are 660 and 300. The car will want to die once the CEL comes on, but goes away when reset, and the damper issue never subsides (thinking it's mechanical).
Any suggestions on where to look next? Does the dampers have a habit of going out in these cars?
Suppose I should have driven it a little more before diving right into the turbo (eyeballs)
Thanks,
Thanks,
