I remember reading once before on how you should have your suspension while install the GT Spec front lower tie bar and the ladder bar, but I have tried searching and cannot find the thread.
So...when installing the two above mentioned parts, should the suspension be compressed(ie. use ramps) or should it be hanging(ie. use jack stands)?
I installed both parts by using jack stands and since then I have a clunking noise that sounds like it is coming from the front drivers side. I have looked under the car and I do not see anywhere that anything is hitting and other suspension parts still look to be in good condition.
Any input will be greatly appreciated. Thank you.
