- 2016 Scion iA
AWR Lower Dogbone Urethane motor mount illegal in ST?!? (EDIT: it is LEGAL)
UPDATED: This mount was found to be LEGAL in STF according to another member's calculations.
v LOOK HERE v
Original Message:
PLEASE NOTE: This is an AWR mount, not made by Good-Win. Corrected in title.
Oh CRAP! I just re-read the rules regarding the motormounts (could have sworn that I read this sooner!)
Here is the 2011 Rule from Page 90 regarding ST class :
Our stock rear mount mostly rubber...
I just installed the AWR urethane motor mount on my Mazda2. Its mostly metal!
So unless I am reading this wrong, that means its illegal! CRAP! :'( And I just got it!
Anybody know of anyone making a non-metal Urethane mount? Is that even a possibility??
v LOOK HERE v
Finally got around to doing some measuring and installing the AWR mount.
In short, it is legal. Not even close. Plenty of metal.
Read the note here to see the pics and calcs.
Original Message:
J. Engine mounts may be replaced, but must attach in the factory
location(s) without additional modification or changes. Engine position may not be changed.
The volume of metal in a replacement
mount may not be increased relative to the volume of metal found
in a stock mount for the particular application. Solid metal mounts
are specifically prohibited. Any non-metallic inserts may be used.
All components between the engine and the mounting structure are
considered to be part of the motor mount assembly and therefore
comprise the motor mount.
