Gas Station POIs
Ft Worth
2021 CX9 Signature
Do your gas station POIs always turn on?
EVERY TIME I start the car (2021 CX-9) my gas station POIs appear. Even after turning them off on the previous drive. I had service look at it, and they claimed to have done something, but the gas station POIs come back on at every start up. It’s getting annoying.
Now that I’m reading this, yes, they are turned on for me. The only reason I noticed it is because I had switched to the Mazda native system from CarPlay to adjust some settings and happenEd to tap navigation and saw the POIs. I did not turn them off at the time because I typically use Apple Maps or Google maps. But I will switch them off and post if they pop up again.
Thank you. I’ve spoken to Mazda service again (after having the car in for oil change and a few other items) and they still can’t give me a clear answer as to the gas station POIs. They said they turned something off for POIs in the settings... but I think they are doing the same thing that I’m doing in the settings... which doesn’t fix anything.
Latest posts
