Hey dude, I sent you $30 last week for a manifold cover. I have not got any responses from you regarding if it was shipped to me. I sent you a PM and an email. What's up?
Intrested in the 1.8 conversion. Is it still up for sale, how much for the VC, bracket, coils and coil wires shipped to 92584? This is the non MSP valve cover so I will not have to modify the spark boot correct? does this also have a CAM sensor mount?
150 plus shipping for full 1.8 coil conversion with valve cover. everything is bolt on ready, onnly modifications needed would be to slightly extend the coil wiring. I didnt extend my wires, i just cut the wire loom off and rerouted the coil wires and reloomed the whole engine harness back together.
You sent me a throttle body with IAC and TPS. True. However, I only needed the IAC. Unfortunately the IAC you sent has the electrical connector completely broken off - not even with the broken piece in the box. It is useless. And I have no use for the rest of it either. So what will you do to fix this? thanks
