Parting out the protege and one of the first things up for grabs is a complete bolt on T3 turbo set up from the manifold to the presilencer pipe.
I am going to drop the price by $50 a day until it is sold. First to pay gets it.
Price drop $700 (July 29th)
Parts and condition:
1) OBX T3/T4 exhaust manifold (has been cracked and welded) 3/10 so will be included for nothing.
2) Tial F38 external wastegage with installed 8 psi springs (also includes a 4 psi spring).
3) Custom dump tube for the wastegate
4) Custom downpipe with O2 bung and manual exhaust cut out.
5) Custom catalytic converter pipe with flex tubing and hi-flow cat (1.5 years old).
6) Garrett T3 turbo (0.60 AR Nissan compressor housing, 0.48 AR turbine housing) Originally off a ford thunderbird.
7) Oil restrictor and drain fittings
8) coolant banjo bolts and fittings
9) gaskets (no exhaust manifold gasket)
10) reworked thermostat housing to clear the downpipe and a flexible stainless rad hose with gaskets (not in the photo)
11) Garrett AR 0.60 compressor housing (has a bit shorter outlet).
12) Braided stainless oil feed line with new 90 degree fitting at turbo (not in the photo)
The turbo has some shaft play and oil blow by. It will probably require a rebuild for serious use. The impellers are fine and have recently been rebalanced. Other than that you can bolt it right up to any 3rd gen protege or P5.
https://www.dropbox.com/s/dwy10v989vvbs16/IMG_20140728_200638.jpg
https://www.dropbox.com/s/2n1f2u0pb1p676r/IMG_20140728_200650.jpg
https://www.dropbox.com/s/d8hol2z0pou2it7/IMG_20140728_200702.jpg
https://www.dropbox.com/s/n6r5gyeymahdj3m/IMG_20140728_200717.jpg
https://www.dropbox.com/s/by7j1n2fipwinan/2014-07-29 19.41.47.jpg
