I have One Brand New Never Been Used MA1800XL F/S. I originally purchased a set of 3 for my truck. But I never had the funds to actually run three subs so I went with a basic box and only fitted Two XL's. I've had this speaker for about a year sitting in my garage thinking of one day using it but that day never came. So I need a little help since I'm in the middle of moving trying to clear out my Garage.
This is a great deal I'm piratically giving them away for dirt cheap you can check anywhere and it easily sells well over $200.00.. This speaker hits hard, All you need is one 800-900 rms watt ampand your good. 140db's easy at 40hz.
I was selling them on caraudio.com but I'm going to change the title on the paperfirst thing 2mar no problem.
LOW PRICE $150.00 + Shipping
Subwoofer Specs
* 1 MA Audio MA1800XL Subwoofer
* 18 Inch Competition Sub
* 1600 Watts Power Handling Capabilities
* 800 Watts RMS Power Handling Capabilities
* Dual 4-Ohm Aluminum Voice Coil
* 350 Oz. (almost 22 pounds each!) Double Stacked Magnet
* Reinforced Ribbed High Foam Surround Technology
* Patented Thermo-Cooling Motor Structure
* Copper Clad Aluminum Voice Coil Wire
* Heavy Duty Non-Pressed Paper Cone
* Ultra Strong Polypropylene Dust Cap
* New Patented Black Die-Cast Basket
* Hi-Temp Kapton Voice Coil Former
* Dual Progressive Dupont Spiders
* Platinum Plated Block Terminals
* Rubber Sealant Gasket
Subwoofer Specs
