goldwing2000 said:Valve cover is definitely plastic. The only cast iron I've found anywhere on this car is the rear upper control arms and the exhaust manifold.
Unless you're talking about some other part and calling it a valve cover?
flameboy: Powder coating can't be done on plastic because it involves an electric charge and then heating in an oven.
mazda3zoom said:bump, cmon someone buy sumthin, im roadtrippin to cali in less than a month and im tryin ta make up for spending $1500 on a motor. (thumb)
FLAMEBOY said:tony,
do you still have the picture of the stock piston? i just want to know whether its an interference setup or not.... coz i'm planning to shave the head....
splitvizion said:are you selling the alt. or the ecu
deezntsz said:just wondering if you have the gearbox or differential cover, I cracked mine and need one someway. thanks,dj
silla3 said:i need the stock intake setup do you still have it. if so how much shipped to houston, tx.??
tsunami said:if the person falls through for the block let me know... shipping might but a kibash on it though....
thebeansoldier said:you have the stock TB without the sensors?
