bpt323
FE3-323
- Madison, WI
- Mazda 5, 323
since i spent 2.5hr searching threads-
Im curious if this has crossed the mind of anyone else....
99-00 = shorter endlink (lower tab mount- pushed further from strut body)
01+/p5/mp3 = longer endlink(higher endlink tab mount)
basically is there any benefit to having the tab raised- perhaps something mazda noticed & revised for "good reasoning"
i had been running these homemade endlinks with great results:
(**not pictured the lower bracket to bolt it to the swaybar**)
but since i've been building my own custom bilstein coilovers its come to more attention & debate on:
which might be better positioning higher vs lower
and also noting- the lower OEM design pushes the endlink slightly further outwards from the strut body itself.
because of my current design where the strut will mount- i'll be stuck with a significantly shorter endlink but with creative welding i can raise the location somewhat.
open to thoughts & further insight.
