Found Protege ES Engine Need Help
ZBlue Bullet
Mazdaspeed Protege
So i got around to pulling out my blown engine in my msp and everything is shot. Hole in block, exhaust valves all bent, the piece between the oil pan and the block is destroyed. Good news is i found a 2003 protege es auto which was in a wreck and im pretty sure it runs all i did was look at it before i go pick it up. What is the difference between the msp engine and es engine internally?
internally to my knowledge they are the same. you will have to install an oil return fitting in the MBSP from the turbo. also route the oil feed, coolant feed and returns. if I missed anything, somebody will chime in.
