i did change to yelow spring. performance wise i don't belive that there is much difference. it seems to hold the boost upt 10 psi as did the blue one, (note i did not have time to test it at higher boosts, which require dreving up a hill at high speeds)
there are 2 differences:
1. the sound BOV makes when it ventilate is of lower pitch and longer, which would make me think that it opens more and allows more air baack into
circulation=less strain on turbo, I belive, could be wrong.
2. it oens after at lower boosts, what i mean is if i only boost to 0-1 PSI and let go the gas pedal, where in blue noe had to boost to pressures over ~5 PSI and than let go the pedal before valve opened. which again in my mind yellow sping (softer on)puts a less stain back on the compressor (turbo) which is a good thing.
so for now i will keep the yellow in.
