So I just installed my Forge BOV last night. After installing it (and I did reset the ECU) and taking it for a test drive, I notice that when acellerating really hard the valve seems to blow off at 4000RPM causing my car to seriously bog down and jolt/stutter. I am running stock PSI and I know the vlave has the green spring inside because I cleaned and lubed the BOV before installing it. Is it possible that the spring has weakend causing it to prematurely vent? What else could it be?
Edit: I now realize the valve is blowing off at 4500RPM accellerating hard or not. I should also mention that I bought this valve used, so some of the problems may be due to wear and tear.
