BremertonMSP said:
Any flow number on this IC?
Which fan hook up did you use for the new fan, and what did you do with the remaining plug?
Thanks
I dont have any flow #s or CFM, but I'm personally using this intercooler on my 89 240sx with redtop SR20det. On my stock T25 I laid down 227hp/256lbs/ft at 4200rpm. The car was running a 13.08@108 on street tires and no LSD. I currently have a t3 60-1 on the car with the same cooler still but have not been to the dyno yet. I'm certain that the flow will be very sufficient for the needs of the MSP, but to handle the suspected volume I'll need for the kit I'm researching other cores. NPR's are getting few and far between for perfect examples. I have found a few Mk3 Supra's running this same intercooler in the range past 400hp, but I would think for the core dimensions that is really on the ragged edge.
We hooked up just the main cooling fan. The AC fan plug is strapped back into the harness hidden away. The car was picked up on a balmy 93 degree SC day and the AC was on constantly with no ill effects. I also let the car sit and idle in the garage for just over an hour and watched the temps.. fan kicked on at regular intervals and the more efficient fan pulled the temps right down.
