Reposting this from another forum..
Hey guys! As some of you may know I've been having the problem with the extremely notchy shifter from 2 to 3 and 4 to 5. I began to accept it as a normal feeling even though it felt like the car was not engaging into the gears as smoothly as the test drive unit. So I brought it into my dealer for it's first oil change and lo and behold theres a TSB fix for early production manual 2.0 mazda3s regarding the shifter. Took it for a spirited drive after my oil change and noticed I don't have to move the shifter like a chess piece and actually shift it like my previous manual cars (miata, mini, bmw).
Below is what it said on my invoice:
Not sure if it's the same number (05-14-01) for you USA folks but try to mention this to your dealer if you have the rough / notchy shifter and get it fixed! Also let us know if it did fix your problem or not
Have fun zoom zooming!!! :Racing 1:
Customer reports transmission feels notchy when shifting. Inspected for TSB. Found 05-14-01 for similar concern. Adjust shifter cable as per TSB for smoother engagement of gears
