Engine swap help
Rotilz
2003 mazdaspeed protege
Hey guys my motor just blew and I need I need to know if the stock protege motor is the exact same
( cams, pistons etc) so I can go out and buy it already
Thanks
Yep exact same, block, pistons, crank, rods, head, cams, manifolds, injectors. Everything is the same except the main bearing support plate/upper oil pan which is tapped for the turbo oil drain (you can re-use your stock one if it isn't damaged) the turbo oil feed line and the turbo water lines which can all be swapped over.
