Yep exact same, block, pistons, crank, rods, head, cams, manifolds, injectors. Everything is the same except the main bearing support plate/upper oil pan which is tapped for the turbo oil drain (you can re-use your stock one if it isn't damaged) the turbo oil feed line and the turbo water lines which can all be swapped over.
