maxek said:I just wonder why my emergency brake light goes on and stays on in cold weather. After I hit my brakes little harder It goes on? Once the car warms up or I shut it off, the light goes off and then comes back on when I hit my brakes again.
zumzumzoom03 said:Hah Somebodies going to ask it ...I might as well.....is the EBrake handle the whole way down?
I got money on fluid level!maxek said:That is a good Idea.
It is probably a combination of pad wear and low fluid plus the cold will contract the fluid in the brake system somewhatAlturredMP5 said:my brake light stayed on when i had bad brakes, too. i changed them, and it was off again. when was the last time you changed your brakes?
gottacatchup said:Mine just started doing this too but its just the e-brake light that stays on steady for a while till the car warms up a bit then goes off. And yes the handle is all the way down. Is there a brake light seperate from the e-brake light?
bradicus18 said:i bet if you added a small bit, you would be surprised at what would happen...
