- 2001 Mazda MP3
it keeps a vaccumm with the mani hooked up. with nothing on it, it will lose some vac
Sweet. Is your vac ok? Do you have pics?Rdshark1 said:I have mine filtered...no CEL.
I'm trying to figure out HOW to fix it. I mean, the car runs fine, I just don't want the CEL. I'm trying to see how other people got the CEL to go away.MPNick said:So get out your tools and fix it.
Kooldino said:I'm trying to figure out HOW to fix it. I mean, the car runs fine, I just don't want the CEL. I'm trying to see how other people got the CEL to go away.
Kooldino said:Sweet. Is your vac ok? Do you have pics?
MPNick said:Drill and tap the exhaust manifold on top of the number # running. Get a brass adaptor thats 1/8th pipe to 1/4 flare{brake line}.
run a 1/4'' brake line to the egr valve. Use exhaust air tube hose and two clamps and you are done.
Rdshark1 said:Far as I know...it's been like this for 2+ years now. When we pulled codes before the only one we got was for running no cats. Fixed that with Vielster's resistor. No CELs since (shrug)
Anywho, I've attached a pic, but it's sorta hard to see. The EGR tube was not going to mate up with the Bosal header so we plugged it at the header (small rectangle), cut the tube back and put one of those small shrouded filters on it (larger rectangle).
Kooldino said:Will brass hold up to the heat?
What's exhaust air tube hose? Where can I get it?
Kooldino said:Do you have a closer picture of the filter? Do you ever get any stalling issues?
You don't get a CEL from having it plugged?Brian MP5T said:Mine is plugged too..
No Problems...
ddogg777 said:I don't think it's a good idea drilling into your exhaust manifold unless you take it completely out and apart from the turbo so that you can clean and chamfer your hole. If you get any bits of metal in your turbo it will hate you forever.(fight)
Ahh, I see. I may give that a shot. Thanks!Rdshark1 said:Okie-dokie. Here are the requested pics. The filter is one of those small shrouded K&N filters, most likely the breather one (gift from friend!).
Please forgive the twisted bracketry and overall dirtiness(thumb)
Kooldino said:Ahh, I see. I may give that a shot. Thanks!
