kalecoauto.com said:Want improved braking? Why just cross drill those rotors? Introducing KaleCoAuto cross drilled brake lines! Improved airflow through lines provides superior brake cooling. Brake fluid is exposed to cool moving air, almost instantly reducing heat, and providing shorter stopping distances! All lines are made of quality latex. Brake lines come in: Red and Yellow. Please specify color when ordering!! Warning!! You must replace ALL brake lines at once. You may mix colors.
Just wanted to pitch in there that if you are going to run rotors that are both cross-drilled AND slotted, it's definitely a good idea to get them professionally cryo-treated. This will not only help the life of the rotors, but prevent warping and cracking over time.
If you guys are looking for some cryo-treated rotors. I can do that for you guys also.
how much extra?
