Hello. I have a 2013 European diesel Mazda 5 with a 6 speed transmission and about 38,000 kms. While driving on the dry highway today, the DSC/TCS warning light came on with the transmission warning light. The car started to shudder, wouldn't accelerate, and the engine was slightly sputtering. I pulled over to the side and stopped, obviously. There were no leaks or burning smells from the transmission and everything else seemed okay. I started it up again and tried to drive, but the lights were still on and the car was not letting me accelerate; it would only shudder and barely move. Eventually, the lights went out and I started moving again, only to have the same thing happen 4 more times about 10 minutes apart - all at highway speeds on a dry roadway with no other issues. The check engine light eventually came on. I was not able to toggle the TCS system off with the switch during these episodes.
There was still nothing obviously wrong with the car mechanicals. I think it must have been a DSC/TCS component failure - causing the car to think it was skidding, which enabled the braking system to intermittently activate. This is likely the cause of the car shuddering and not accelerating. There was no indication of an ABS component failure (no ABS light).
So, I disconnected the battery temporarily, hoping to clear the failure. It worked. I drove the car 350 kms home with the TCS switch off and the check engine light on. The car largely acted completely normally. Yes - I know I probably shouldn't have driven that far in those conditions, but everything here is closed on Sundays....and managing this issue in a foreign language without a computer would have been difficult.
Now the car still has a check engine light and I want to figure out what happened. I know from searches, that there are TCS/DSC issues in the past - but I wasn't aware of them leaving people on the side of the road like my car did today.
Before I take it to the dealership here - does anyone have experience with this kind of failure? I am assuming some kind of relay or module failure in the DSC/TCS system. I am not thinking it is an ABS wheel spin sensor, but I guess that could be the cause too.
Thank you in advance for reading this story and providing any advice you have.
